M1101 4 pin to 12 pin-no brake lights help, please
hound46
MO
I "think" I did everything by the numbers in wiring a 4 pin connector to the 12 pin male trailer end. I switched the 24 volt incandescent lights in the tail lights for their 12 volt counterparts. The LED and incandescent running lights and blinkers work. The brake lights don't. Is there a possibly simple reason and fix for this? I've googled and searched. No luck. I thought the blinkers and brakes ran on the same wire?
glassk
Hampton, GA
maybe those numbers were wrong
ke5eua
41
Baton Rouge (Central), LA
Kinda odd you have turn signals but no brake lights as they are on the same circuit comming off the 4 pin connector.
--- Ground
--- Tail Lights (Running Lights)
--- Left Turn Signal (Brake)
--- Right Turn Signal (Brake)
Disconnect the adapter you made and use a known good trailer as a test subject to see if your vehicle is working correctly. A VMM (multi meter) can be very handy also in figuring this out.
Change pictures.
hound46
MO
I think the answer lies somewhere in that Toyota runs a 5 pin plug and to go to 4 pin, you need some sort of an adapter. I think the previous owner of my vehicle may not have done this.
1,824
Bingo! Knowing you were working with a 5 wire vehicle in the first post could have netted you with correct info there. There is a converter needed for 5 wire cars and trucks.
hound46
MO
I had a Ford 250 for 16 years. I saw the 4 plug on the Toyota and thought it was stock like on my Ford. Previous owners father says it's not stock and thinks there's a converter that wasn't used. Everything is easily accessible so I just have to learn about the 5 to 4 pin adapter and where to put it. Had my head spinning for 2 days. The 4 to 12 pin conversion I did seemed simple and logical. Back to the books.:cookoo:
ke5eua
41
Can get the little black boxes at Walmart, autozone, etc
hound46
MO
That's good to hear. Are you familiar with what goes where before the 4 wires(I'm assuming) leave the box?
hound46
MO
It's a 2008 FJ cruiser. Some Google and more educated searches should help now that I know what the problem is, but personal experience/knowledge you may want to share would be great.
