M151 lives
ida34
35
Dexter, MI
I got the M151A1 running today. I put a boat tank on the carb and pumped the primer bulb while taking out the main jet. I pumped until clear gas came out from the bottom of the carb. I replaced the jet then shot some either in the carb. I put in my cucv batteries and checked to make sure I was getting power to the distributor. Everything looked good so I hit the starter switch. She fired right up and built up great oil pressure. She ran great until the carb ran dry. I now need to take out the fuel tank and clean it out with acid. It smells bad of rotten gasoline. The pump does work. There was no fluid in the master cylinder. I filled it up and pumped up the pedal. I had my son hold it down while I looked for leaks. There were none. I will have to bleed them but could find no leaks. The plate on the thing is from 1979 and no telling when it was last running. The trans goes into 1st and 2nd. The shifter would move to the right but would not go up or down to go into 3rd, 4th, or reverse. I will have to look into this later. At least she runs.
Stay tuned. More to come. Don't touch the dial.
ida34
35
Dexter, MI
I had planned on getting a video but like usual I started working on it at the last moment when I got something else done. I forgot about getting the video until about an hour later. I blamed it on my son. I will have pics when I drive it around.
