M35A2 towbar Question
panzerjunky
san diego ca
Hello Gents
What is the correct size tow-bar for the deuce I see them in med and Lg and will the deuce tow-bar work on an M715? Next who has one and how much do they cost/
Thanks Jerry
rosco
32
Delta Junction, Alaska
Medium. The large takes a crane to move around. Not sure of the pin size on the 715. But the feet are interchangable, to acomodate different pin sizes. The deuce is one inch.
Lee in Alaska
M813A1
OKC, Oklahoma
M715 takes a 3/4 " pin and the medium tow bar .. The Medium toe bar with 1 " tow bar feet is correct for the Duece and 5 Ton trucks . The CUCV, Hummer, M715 use the 1" pin to 3/4" pin on a medium tow bar !!There is alos a medium light tow bar for the CUCV, M880, M715, Hummer and M151 trucks as well .
1,824
Don't forget that the M715 has specific adapters because of the lift shackle configuration. These may be more difficult and expensive to find. Check the classifieds, saw one in there yesterday. Ebay could be a decent route depending on where it ships from. Weight with deuce adapters and pins is right at 142#.
JAYHAWK 1962
tijeras, nm
hey panzer there was someone in california selling a tow bar in the classified section. shippin would be a lot less and i think it was in the 250-300 dollar range.
KsM715
142
St George Ks
Yes, without my counter weight back there, moving the heavy towbar around makes that little tractor a bit tippy. (glad I wised up and traded off that towbar and got me a medium)
Gimpy, you gonna make the OP a deal on half a towbar?rofl Actually a quarter of a towbar.
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
If he wants one sure. I am already working on the rest of the parts for a completed bar or two. I'm sure I can get slave cables too, just not sure what thier owner wants for them yet.
shepsjeep
Louisburg, KS
A Medium Towbar is the size to use on an M715. Also the adapters are necessary due to the bumper / shackle configuration. They are REALLY hard to find and will cost almost as much as a towbar if you find them. Check out the attachment.
