M35A2 Transmission Fluid
dropaduece
harpers ferry, wv
Dear Fellow Members,
I have recently added a pto to my m35a2 and had to drain all the old transmission fluid. I would like to put some fresh oil in yet am not sure what to use.
80w 90w gear oil okay? Any advice would greatly be appreciated.
Seth
jimm1009
71
Louisville, KY
your tranny oil
Use GL-1 or GL-5 with Yellow Metal Compatability.
Napa sells it in 5 gallon pails. Same oil for the axles and transfer case too.
If you pick GL-5 make sure it is good for yellow metal.
I'll look for my bucket and post again when I have the part number off the pail.
Jim
jimm1009
71
Louisville, KY
tranny oil
O.K. Here is the information off the 5 gallon pail from NAPA.
White bucket with blue and silver lettering.
part number SUS52
Super-S 80W-90 Gear Oil
GL-5
It does not say on the bucket that it is good for Yellow Metal so I had BAPA call the manufacturer and they stated that it was o.k. The Hazmat sheet has it but the bucket does not. Go figure!
It was about $59.00 per pail about four months ago.
Attached is the one page of the Lube Order showing the oil type and capacity. 8 1/2 pints with PTO. GL-1 was the original oil but very hard to find and the modern GL-5 is better these days.
Jim
jimm1009
71
Louisville, KY
Go to the first knuckle on your index fingure. Don't actually fil-to-spill or it is slightly overserviced.
Jim
PS: I can send a picture of the actual pail if you give me an e-mail adress but all the info is in above post.
jimm1009
71
Louisville, KY
tranny oil
Put your index finger (first finger next to your thumb) in the hole to the first joint and point down.
If and when your finger tip gets wet, it has enough oil. :p
Hey Gringle, PM or e-mail me, I have a brake question for a master brake man.
Jim
jimm1009
