M35A2 Transmission
Slate
378
Ozona Texas
Replace gears or clean up pieces and change oil and run?signal-2019-08-14-114216.jpgsignal-2019-08-14-114216-1.jpgsignal-2019-08-14-114216-2.jpg
Sent from my moto z3 using Tapatalk
Menaces Nemesis
"Little Black Truck" Conservator
262
Denver, Colorado
If it were mine, I'd replace those gears. 1st gear will be easy on the mainshaft since it slides right off once you get the mainshaft loose. I believe the corresponding gear is milled into the countershaft itself, so you'll have to replace it. It's all really pretty easy, just follow the TM, and take pics with your phone along the way so you have a nice reference as to how retainers, spacers, bearings, etc. go back in. Was it shifting okay? now would be the time to do a full gasket kit, and replace syncros, shift forks, and bearings if they need it. For the parts you need here, White Owl would be the vendor among the usual suspects that I'd call first (unless you need a mainshaft. I bought mine from Boyce off Ebay for $50. Be surprised if anyone could beat that). If you need a press, here's a coupon to get a 20-tonner from harbor frieght for $145 http://www.hfqpdb.com/best_coupon/20+TON+SHOP+PRESS. If you need a bearing separator to squeeze the gears off the shafts, you can get one from HF, or Ebay is a good source too. Take a little time now to get it all in good shape, then when you take your truck for a drive, you can look down at the trans and say to yourself "I've been in there... it's all good".
Transmission TM; https://www.steelsoldiers.com/showt...2-Ton-Trucks&p=1978748&viewfull=1#post1978748
Make sure you do the oil drain-back mod, to the rear main retainer, here on page 4-136, if it isn't done already; https://www.steelsoldiers.com/showt...1C-LDS-465-1&p=1978757&viewfull=1#post1978757
Slate
378
Ozona Texas
I have a full gasket kit. And yes It shifts better than my other 2 trucks. I'm just to a point I have basically built this truck over the last couple months got it nice and pretty and runs great. Main seal was pouring oil out so tore into everything and now I am going to have to go through tranny as well. Flywheel redone new clutch. Ever just get to the point where you want to drive it and not be doing major work on it? A little maintenance ok but man. Just frustrated.
Slate
378
Ozona Texas
Anyone ever heard Charlie Robinson. Loving County? "Like a thousand tiny diamonds in the lights of Loving County". That's what my pretty oil looked like flushing out my transmission. So....... beautiful
cattlerepairman
3,463
NORTH (Canada)
Oh, man....I hear you....just want to drive the thing, not do brain surgery on it. I sure got there two years ago when I got to do a surprise engine rebuild.
On the plus side, you have the tranny out already and now is the time to rehab it. In a way, better than putting a new clutch, resurfaced flywheel in, re-mounting the tranny and have it grenade on you in a month. Sorry, trying to be positive! You will have a freshly painted transmission, yay!
Slate
378
Ozona Texas
So tranny flushed cleaned new oil and man she feels good. New clutch and main seal. No Leaks. Need to find parts and a rebuilt transmission or NOS to replace then rebuild the one in the truck. Thanks for the encouragement and support.
Slate
378
Ozona Texas
If I have a high pitched whine from clutch when depressed did I not get it adjusted right?
Slate
378
Ozona Texas
Yes Sir. Got a kit from C&C and replaced it all. New clutch disk, plate, and bearing.
Throwout and needed a little more adjusting.
