M35A3 Keyed Ignition Switch Install
joenavy203
norfolk
anybody ever try a hidden battery disconect switch turned on and off with a lock sellinoid run through a key fob??? easy way to kill all power and at least make someone trying to steal it have to trace out the battery lines to find the kill switch and it also makes it easy for the owner to turn it on and off without having to climb underneith the truck.
AceHigh
32
Lake City FL
Not as fancy as you describe Joe but I drill a hole under the passenger seat, install a Caterpillar on-off switch (keyed) and hook up a 2 foot battery cable from the battery to the switch. I then hook up the trucks negative battery cable to the other side of the switch. Real easy and keeps the batteries up.
