M35A3 leaking fuel near filter
glcaines
2,806
Hiawassee, Georgia
I'm glad you have solved the problem. Cleaning the check valve should be SOP for A3s. Mine even looked like it had some hair or fibrous material mixed in with the gunk.
Hoefler
21
White Bear Lake,MN
I pulled out what looked like an eyelash or brow in the check valve area. Maybe the people who put these together should wear hair nets and practice better grooming.
CanonNinja
Houston, Tx
my truck has been great ever since. but i need to clean the tank out. my truck was a Katrina truck from Ft Polk, so its got random rust from piece-meal post-flood PMs
Hoefler
21
White Bear Lake,MN
Found the leak near fuel filter.
Took the entire assembly off of engine. There are O-rings in the fitting for the lines in and out of housing-pulled the TM on it-brought it to CAT and they found the proper O-rings. The elbowthat screws into side and the tee on opposite side have another O-ring that seals the fittings that screw into housing. Discovered that these arte leaking-perhaps they where the culprits all the while. I will be replacing these out and hope to have this thing sealed up nice and tight. Note-the MIL version of the filter assembly-mount is different than commercial CAT engines. I have the part number for the small sline O rings if anybody needs. Next week I will source the larger fitting O-rings-I will get that part number as well.
A buddy of mine gave me some fuel algea shock treatment for tank. He has bad algea in his trucks-shocked the tanks and killed all the algea. This should keep the lines clean and dependable.
