M35A3 V belt and serpentine belt
unispeed
Akron Ohio
My m35a3 is about 50 miles out with a reported serp and waterpump belt broken
I got the the 7 rib 65in for the serp but can't kind find what vbelt for the water pump
appreciat any quick reply
thanks mark
Happyland1410
Ada, Oklahoma
unispeed
Akron Ohio
well they reported that it was just the serpintine
I found a 65.5 inch 7 rib on saturday at Summit Auto Racing
Don't bother buying one
it is way to long ot even see how a 65 will make it but the idler wont even touch the 655
I had them drive at 2300 rpm temp stays at 200 with 90 out side what a beast! went over 80 miles back in the cave.....
thanks everyone for the support!!!!!! :D:razz:
Mark
unispeed
Akron Ohio
thanks AZ
Access Dayco
I tried both thos numbers at dayco .com and eve a ray goodle yeild ???BLa
I am just trying to accumulate a commercial cross reference....
Dayco how old is that ? was Mil NOS?
if you got a lead
Man my internet searched I thought was not haf bad but that pic belt and numbers stumped me????????
M35A2-AZ
416
Tonopah, AZ
thanks AZ
Access Dayco
if you got a lead
I was doing the same search will little luck. I think it is a Mil NOS.
The date on the belt is 2q-07-10.
I found a thread that said it was a 65" 7 rib.
Let us know what you find out about the P/N.:beer:
Happyland1410
Ada, Oklahoma
I have also been searching and found a little more info:
Here is a cross reference for serpentine belts:
Serpentine K Belt Cross Reference - 7 Ribs K Series
Here is the part info listed on Erik's Military:
"Belt for M35A3 (CAT 3116 engine) used to drive the fan and alternator. p/n 12448759. NSN 3030014601030. OEM part, made in USA. Also replaces RCSK17002-2, 7PK1639."
If you look at the metric number (7PK1639) then check the cross reference site above and find 7PK1640 is the closest size. If you check Dayco's site you will find part number 5070646 (not 5070645). If you pull up the details for 5070646 it gives the metric part number of 7PK1640.
Access Dayco
Everything pints to this belt being around 64.5 inches long but it is strange that nothing seems to match up exactly with the military numbers.
unispeed
Akron Ohio
Made it home what i found out
I got a 64.7 inch 7 rib belt from O'Riely's Plendy of tensioner left
also order a gates KO70644
Product Description
Features Advantages: Replaces belts on serpentine drives and other V-ribbed belt applications. Designed for small diameter pulleys, backside idlers and automatic tensioners. Belt construction eliminates noise, reduce tension loss and solve problem drives. Tensile members and rib reinforcement added for wear and crack resistance. Meets or exceeds SAE J1459 specifications. V-ribbed on both sides of the belt.
Belt / Sprocket Specifications
Effective Length (in): 64.44
Effective Length (mm): 1637
Number of Ribs: 7
Outside Circumference (in): 65
Outside Circumference (mm): 1651
Top Width (in): .947
Top Width (mm): 24
Customer Pack: 1.0
Standard Pack: 41
Product Attributes
Section: K
Weight
Weight (Lbs.): .44
K070644-GATES CORPORATION-Micro-V AT Belts
looks like a nice belt and it is tuck in the glove box
now i will get the v-belt
thanks you guys for the feed back......
1,140
