HDN
- 5,577
- 113
- Finger Lakes Region, NY
I'm looking at purchasing an M35A3. It's been sitting for about ten years, but it starts right up and everything works, except the transmission won't shift out of first gear in the drive position. Doesn't matter if I'm in high or low range. Run the engine up to 2500 rpm and it just doesn't want to get out of first gear.
I checked the oil level for the tranny and it's good, but the tranny oil filter hasn't been checked. Maybe it's clogged and causing problems?
The truck can go in reverse just fine. The gas pedal is a bit sticky though, but I heard the throttle cable sheath gets gunky with lack of use.
Any thoughts?
Any thoughts?
