M52A1 spedo cable adapter which one?
jamboly
Brenham, TX
The speedometer cable adapter on my M521A1 (MACK) seems to be the cause of the speedometer not working. The -20P parts manual calls out two different adapters. A regular one and one with a drive ration of 26 to 1. Does anyone know which one I would need? (transmission is an overdrive transmission).
73m819
327
gainesville, ga.
7409623 is the p/n for stock with 1100x20s, over drive trans does not matter
73m819
327
gainesville, ga.
do not know about m35, but for the 5t ton, it is the correct p/n, out of the ord-9, the 211, 260 tms, there is a different p/n for 1400x20s, 1200x20s (246,819)
jamboly
Brenham, TX
What is the date on your 211 manual? My 211-20P & 211-35P (w/change 2 dated 1989) show needing 99673R1 NSN 2520-740-9623 for 1100x 20 tires.
jamboly
Brenham, TX
I did some more looking after my last post. The M800 series manual has NSN 2520-740-9623 as a 7409623, so that is what I will go with.
73m819
327
gainesville, ga.
7409623 is used with 1100x20s on ALL 5T, from the 6602 gassers to the 250 809s
Not sure but may be used on m34/35s with OEM 1100x20s, because the speedometer is the same as the 5Ts,
