M52a2 transmission and transfer case seal replacement
topo
281
farmington NM
I'm working on my 67 M52a2 replacing some seals in the transmission put out shaft and transfer case in put also new seals and gaskits in the PTO . The space between them is like 9 inches. I'm using a torque multiplier and a 2 1/8 socket the torque multiplier I could not pull hard enough to unscrew the nut in the space I had I used a jack to pull and broke it free .The tool I made is to keep the yoke flange from turning .
