M548a1 cargo carrier parts
mym35a2c
dixon cal
M548a1
Looking for some T130 track and idler wheels. Also looking for any parts that are for an m548 for back up parts.
thank you
drspooks
mn
M548a1
thank you
easternsurplus.net has used track for sale on their website. i have no idea the condition of the bushings. i have not purchased any. secoparts.net has new t130 track for sale $215 per link. i think sparrowhawk inc on ebay has the idlers used. best of luck, i am searching for m548 parts also. my machine had a battery fire so the inside of the cab is destroyed. and its not like im trying to find honda civic parts.
drspooks
mn
not quite that bad. pics are not the best but what i have at the moment. drivers door and latch side are melted, steering levers are 12inch nubs, seats are gone and drivers seat structure is melted away, all glass gone, soft top supports melted away, fire was only in cab though and didnt damage the cab floor, all the major components are still good engine, rad, trans, t-case, diff, all good. tracks at 80+%, road wheels 95%, lots of good to work with. fire could have been a hell of a lot worse,
mym35a2c
dixon cal
Thank you. For the info. I was fortunate enough t mine came with a lot of spare parts. I got the front drive gears and I found the road wheel up north for a great price. Where are you located. I’m just outside Nashville
drspooks
mn
Im in minneapolis, my machine is in northern mn. Not sure how much knowledge you have on these machines but i have 28 tec manuals on my computer for this machine and the cross over to the m113 family.
heres the list
TM 9-2350-247-10 Operators manual for carrier cargo tracked 6-ton M548A1 NSN 2350-01-096-9356 M548A3 2350-01-369-6081 carrier electronic warfare systems tracked 6-ton M1015A1 2350-01-136-8745 TM9-2350-247-10
TM 9-2350-247-20-1 Unit maintenance for carrier cargo tracked 6-ton M548A1 NSN 2350-00-096-9356 M548A3 2350-01-369-6081 carrier electronic warfare systems tracked 6-ton M1015A1 2350-01-136-8745 TM9-2350-247-20-1
TM 9-2350-247-20-2 Carrier cargo tracked 6-ton M548A1 2350-01-096-9356 EIC AEU M548A3 2350-01-369-6081 EIC AE9 TM9-2350-247-20-2
TM 9-2350-247-20-3 Unit maintenance for carrier cargo tracked 6-ton M548A1 NSN 2350-01-096-9356 EIC AEU M548A3 2350-01-369-6081 EIC AE9 TM9-2350-247-20-3
TM 9-2350-247-24P Direct support and general support maintenance repair parts and special tools lists including depot maintenance repair parts for carrier cargo tracked 6-ton M548A1 NSN 2350-01-096-9356 carrier cargo tracked 6-ton M548A3 2350-01-369-6081 TM9-2350-247-24P
TM 9-2350-247-34 Carrier cargo tracked 6-ton M548A1 NSN 2350-00-096-9356 M548A3 2350-01-369-6081 carrier electronic warfare systems tracked 6-ton M1015A1 2350-01-136-8745 TM9-2350-247-34
TM 9-2350-247-10-HR Hand receipt manual covering basic issue items bii and additi authorization list aal for carrier cargo tracked 6-ton M5 NSN 2350-00-078-4545
TM 9-2350-247-PCL Combat vehicle pre-combat checklist for carrier cargo tracked 6-ton M548 NSN 2350-00-078-4545
TM 9-2520-238-34 Right angle drive cooling fan M113A1 FOV M113A2 FOV NSN 2990-00-712-1280 M730A2 3010-01-202-0955 M113A3 3010-01-242-4747 Gearcase transfer M667 2520-00-800-3405 M548 M548A1 M730A1 2520-01-047-8613 SERVICE GEARCASE 2520-01-087-0156 M1015 M1015A1 2520-01-239-1782 M113A1 FOV 2520-00-572-8605 M113A2 FOV WITH 100 AMP generator 2520-01-061-5570 M113 FOV WITH 200 AMP generator P/N 12349527 drive assembly final M113A2 FOV M113A3 2520-01-061-5766 M548 M548A1 M1015 M1015A1 TM9-2520-238-34
TM 9-2520-238-34P Direct support and general support maintenance repair parts and tool lists including depot maintenance repair parts and special for right angle drive cooling fan M113A1 FOV M113A2 FOV NSN 2990-00-712-1280 M730A2 3010-01-202-0955 M113A3 3010-01-242-4747 gearcase transfer M667 2520-00-800-3405 M548A1 M730 M730A1 2520-01-047-8613 service gearcase 2520-01-087-0156 M1015 M1015A1 2520-01-239-1782 M113A1 FO 2520-00-572-8605 M113A2 FOV 100 AMP generator 2520-01-061 M113 FOV 200 AMP TM9-2520-238-34P
TM 9-2350-277-20-1 Unit Maintenance Vol 1
TM 9-2350-277-20-2 Unit Maintenance Vol 2
TM 9-2350-277-20-3 Unit Maintenance Vol 3
TM 9-2350-277-20-4 Unit Maintenance Vol 4
TM 9-2350-277-20-5 Unit Maintenance Vol 5
TM 9-2350-277-20-6 Unit Maintenance Vol 6
TM 9 2350-277-24P Organizational Direct support and general support Support Maintenance Repair Parts and Special Tools
TM 9 2350-277-34 Direct support and general support Support Maintenance
TM 9-1240-216-34 Periscope tank M19 NSN 1240-01-005-6035 periscope tank M24 1240-01-005-6036
TM 9-2350-275-BD Operators organizational direct support and general support maintenance battlefield damage assessment and repair for M113 family carrier personnel self-propelled full-tracked
9-2520-272-34&P Intermediate direct and general support maintenance manual including repair parts and special tools list for cross drive transmission w/container model X200-4 NSN 2520-01-201-4784 Detroit Diesel Allison Division GMC
TM 9-2540-205-24&P Organizational direct support and general support maintenance including repair parts and special tools for heaters vehicular compartment Stewart-Warner 10560M NSN 2540-01-071-065110560M 2540-01-169-5159 10560C24 2540-01-083-0691 AND 10560G 7540-01-262-6013 HUPP MF60A-24V 2540-00-930-8938 MF510B 2540-01-071-0652 MF510C MF60B-24V 2540-01-162-3834 ESPAR 2540-01-114-7688
TM 9-2920-257-30&P Direct support maintenance manual including repair parts and s tools for generator alternating current 200 amperes NSN 2920-01-147-1575
TM 9-2540-207-14&P Heater vehicular compartment NSN 2540-01-396-2826 model A-20
TB 9-2350-368-25 Fabrication and operation of power plant test STAND M113A2 M113A3 M548A1 M548A3 family of vehicles including opposing forces surrogate vehicle osv
TB 9-2350-369-20-1 Instructions to convert t130e1 track to T150F track using kit 57K4269 2530-01-502-3401 M113A3 carriers M113A2 carriers M548A1/A3 carriers AND OSV MBT vehicles
TM 55-2350-224-14 Transport guidance M113 family of vehicles M113A2 M113A3 M10 M125A2 M548A1 M577A2 M667 M730A2 M741A1 M901A1 M981 M10 M1059 M1064 AND M1068
