M715 Coil
Knottofs
White Level, NC
Replaced the Distributor "Which worked" With a newly rebuilt one. Now im not getting any spark. 24.7 Volts are going to the coil at its + side. How do i check and see if the right amount of power is leaving the coil? Also, then put old Distributor back in , and now im now getting any spark out of it. Any way to check the coil? Any Ideas, would be much appreciated.
P.S. sorry about my last post, I have no idea why i was calling it a Carb.Thanks, NateO
chimesickle
Galway, NY
Yes, I have had a half dozen of those Chinese coils. If you leave the ignition on and forget about it, it will kill the batteries and coil. This happens when I stall it, or I am just working on it and forget. If it is hot out, the coil will start to fail. Maybe part of my problem is that the distributor isnt vented correctly, I need to replace some vacuum lines
