M809 front winch spins the wrong way
bigred350
shelton/CT
Hello I put a winch/pto from an m809 on my m52a2, when I pull the lever up the winch drum spins forward like its paying out cable and in the down positions low/high the drum spins backwards towards the truck like its winching, but everything ive seen and read said it should be the other way? As far as I know the pto/driveshaft only work one way, is it possible something in the winch is reversed? or am I completely over looking something? right now the cable has to be under the drum to winch but it should be over the drum. Thank you.
topo
282
farmington NM
The front winch on my m52A2 was like that it payed off from the bottom some time back I unspooled the cable and put it on the right way
bigred350
shelton/CT
Yes, but unspooling the cable and routing it the right way will change the lever controls in the cab. correct?
topo
282
farmington NM
In my notes I keep I wrote pto shaft all the way out is reverse pay out
5/8 of an inch is natural
push in another 5/8 inch is low
push in another 5/8 inch is natural
push in another 5/8 inch is high
I'm working on new seals on the pto and new seal in the out put of the transmission and new seal on the tranfer case in put now and every thing is apart.
US6x4
2,484
Wenatchee, WA
In case this helps, this is how my M813 winch cable starts out. It appears that the wire rope exits the spool from the top and then goes under the large roller.
