Jersey4x4
- 1
- 18
- Absecon, NJ
So I did the search thing and looked in all the TMs and can not find it so here it is. I have a M816 with all oem wiring and I want t to stay that way. I have a bad ground on the drivers side headlight. The light is dim and the High Beam indicator lights up very dim when in Low beam mode. When in High Beam mode the indicator gets bright as it should. Anyway, where is the ground located for the drivers side headlight. I traced it to the harness but it is all taped up and goes under the rad cross member to the passenger side but after that I don't know where the ground terminates. I did not want to cut open the wire harness and do exploratory surgery so I figured I would ask here first.
