M221
- 0
- 1
- O'Fallon MO
How is the brake switch supposed to look ? Mine is located on the frame rail and above the air pack. With a j shaped air line feeding into the middle.
The electrical post on the left looks normal to me however the one on the right has a cover of some sort on it and how it could ever make a connection with the normal military connector I wouldn't know.
Both connectors look the same and look like they should slide over a post just like the one on the left of the switch.
I got into this situation because the brake lights were on all the time. I disconnected the wires to the switch to see if the switch was stuck on and now I can't get the connector back on that strange cap on the right side of the switch.
If I can get past this problem I can probably fix the situation but I'm stuck. Any help would be great. I couldn't find any specific information in other post or TMs for this switch and how it should look.
Thanks in advance
Thanks in advance
