M920 pto pump
AMgeneral3945
Fond du Lac, WI
The seal on the pto pump went out and mixed with the transmission oil. Looking for a seal kit for the pump and where the pump mounts on the trans. Wondering if anyone knows where to get them. Or should I put a different pump on it that has one outlet? Also, are there pto pumps that allow you to shift while pumping for M920s?
simp5782
Feo, Fuerte y Formal
9,513
Mason, TN
The stock pump is two 20gpm pumps together. It uses 1 to power the low speed on the winches. The other is winch power, however this fluid gets split and sent to the speed side in the event you use high range on the winch.
@superman has the pto pumps available new in the box.
If you switch pumps. The current setup is CCW for rotation.
You can use the PTO in 1 - 4 gears on that CAT transmission
AMgeneral3945
Fond du Lac, WI
Is it just a standard pump like any other truck with a wet kit?
