M923 A1 Brake Pedal Issue
hawkeyehenry
Nashville, TN
Sure could use some help with this issue. The brake pedal is sticking when I apply pressure and does not return to the normal position.
Thanks in advance for your recommendations.
Hawkeye
Swamp Donkey
The Engineer
126
Gray, GA
There is a long external spring the pulls the pedal back up after release. Is that broken or missing?
hawkeyehenry
Nashville, TN
The brakes release just fine. The pedal does not return to it sticks and I have to pull it back to the non pressure position.
Thanks for the repair manual and for taking the time to share your ideas about the issue.
simp5782
Feo, Fuerte y Formal
9,511
Mason, TN
Will bump this with some part information.
E7 Brake Valve Replacement - Just the valve - No Pedal -
Bendix 286775
