M923 NHC250 stalls when stopping. Idle seems low too.
1 Patriot-of-many
88
Zimmerman MN
How do I set the idle higher on the NHC250? Starts right up, but releasing the throttle suddenly it will die, or driving forward or backward and stopping it will die.. I replaced the big canister filter recently but still have the issue. Any suggestions on a sight glass to install in the fuel line before the pump to see if this is air in the fuel?
carlandedith
Sapulpa, Oklahoma
It sounds like your getting air in your fuel line.
I had the same problem before, it started out with a lose of power then started dying at idle.
My fuel line was coming lose where it feeds into the injection pump
Bill Nutting
1,370
Chesterfield, Mi.
Because the fuel is being sucked from the tank, finding air leaks can be hard. Mine was loosing prime and it made it hard to start. I installed a 24volt electric fuel pump at the tank so I was pushing the fuel up to the engines fuel pump. After running at an idle for a few minutes, we spotted the leak. It was a plastic bypass tube on the fuel pump (I think). I replaced the cracked line with copper and it hasn’t lost prime since. Once I found my problem, I removed the electric fuel pump but left the fittings in place. This way if I ever have to look for an air leak in my fuel system again, I can simply put the electric pump back in to pressurize the system...
