M923A2/M939A2 driver's side glass
kymidnight
Marengo IN
Anyone know the size for a M923A2's driver side door glass? I broke it and would like to replace it, but I don't see any reason to buy a whole new unit for $200 when I know I can get some laminated glass and redo it myself. I didn't know if anyone knew what size piece of glass I should get.
I searched and found the M35's glass size on the forum, but didn't see it for the 5ton anywhere. (But I'm also notoriously stupid with searches)
Thanks!
Swamp Donkey
The Engineer
126
Gray, GA
Find NSN for glass in the Parts TM...
NSN 9340-01-047-4100
Enter NSN into Parttarget.com and get all the information you'll ever need.
ABHP Overall Length 29.359 inches nominal
ABMK Overall Width 21.000 inches nominal
ADUM Overall Thickness 0.234 inches nominal
ADZC Environmental Protection Any acceptable
AJHV First Corner Radius 0.062 inches minimum and 0.125 inches maximum
AJHW Second Corner Radius 0.062 inches minimum and 0.125 inches maximum
AJHX Third Corner Radius 0.062 inches minimum and 0.125 inches maximum
AJQE Material Transparency Clear
AKVK Fourth Corner Radius 0.062 inches minimum and 0.125 inches maximum
AQQR Edge Type Flat finish
MATT Material Glass laminate
MDCL Material Document AND Classification DD-G-451 fed spec single material response
STYL Style Designator Rounded corners
kymidnight
Marengo IN
The thread for the m35 said "Laminated safety glass, clear, 745mm x 533mm x 6.3mm" which if I do my math right is basically 29.3x21x0.24. Which matches up pretty closely to the website.
Swamp Donkey, wow, thats an awesome resource, thanks!
