74M35A2
- 340
- 83
- Livonia, MI
Replaced fuel level sender. New sender has plastic float, and is height adjustable via sliding bracketry and screws. It is working but not exactly accurate (ran out of fuel before reaching "E"). I once saw the adjustment procedure for this, and have not seen it since. If I remember correctly, it was just a simple measurement. TM just states how to replace sender, not calibrate it, unless I missed it. Unsure if the sender came with instruction of how to do so, because it has been a while now, but usually this is not the case. I'd like to calibrate it correctly, and not just "keep it above 1/4 tank". If somebody has or knows where this procedure is, it is greatly appreciated. Otherwise, it will be trial and error as best can be with a tape measure and gauge readings. The darn angle fill neck tank won't let you fill it all the way up anyway. I am prepared for lashings if somebody posts a TM link.
