74M35A2
- 339
- 83
- Livonia, MI
Hi all. Seeking the hydraulic flow rate and bypass/relief valve pressure setting in the hydraulic system of the M925A2. WildChild467 has found the minimums for me, which are spec'd out at 800r's engine speed, but they are minimum test specs.
I am converting over to 24V solenoid type hydraulic valves for my front winch and the same winch which I am soon installing in the rear, and therefore need to know how to size them appropriately. I have seen 25gpm mentioned on the pump, but is this at 2000rpm engine speed? Also I believe the hydraulics of the winch up front simply go into bypass/relief if the winch is over-loaded, so I also need to know the approximate pressure at which this occurs. There is a significant cost difference between 3000psi and 4000psi 24VDC solenoid valves.
Thanks, and apologies if I have missed it in the TM's or other posts.
