M929 Dump Truck PTO removal
dan2002dd
23
ellaville, ga
I have a M929 5 ton dump truck with a PTO problem. I have searched on the site for anyone who has removed a PTO with no luck. I have located the procedure in the TM but my concern is the frame of the truck. There is not much room and I wanted to verify that it can be removed without dropping the transmission. And I tried to just remove the top but there is not enough room for to come out. Do any of you have any experience with this or any recommendations?
simp5782
Feo, Fuerte y Formal
9,493
Mason, TN
Remove the rear mount transmission bolt. Put a scissor jack against the frame and rear of transmission and put pressure
Pto will slide down the frame to the rear and out
dan2002dd
23
ellaville, ga
I finally got around to getting this done and was able to slide the PTO out without moving the transmission. The hardest part of the job was removing the driveshaft as it took a lot of hits with an air hammer. I was able to get the PTO repaired and back on and the truck to dump but still have to install a new PTO cable and since it is missing all the parts, I'm planning on just installing a simple pull cable in the floor. Anyone have any thoughts on why that wouldn't work?
20,483
It isn't pretty, but a cable will definitely work.
The KEY will be to not "cheap out" on the cable. The outside of the cable should be about the size of your little finger. Yeah, you can buy the $15 version that looks like the cable on your push lawn mower but a few months later when that cable is rusted - your PTO won't be working very well. BE SURE to make the cable support out on the PTO side out of some beefy scrap metal that you have laying around. You don't want your support moving while the cable is moving...
dan2002dd
23
ellaville, ga
I was originally planning the cheap cable but have reconsidered. I believe I have the support that bolts to the PTO so I should just be able to install it and clamp the cable to it. I found a cable I had salvaged from an old bus transmission shifter that is very similar to the original that I can use instead. I just have to figure out a handle on the cab side.
20,483
Sounds to me like you already have the "ingenuity gene" so with a little time, you should be able to work it out. Best on the plan!
