M936 A2 Parts Assistance
PowerstrokeNC
Greensboro, NC
Had a fairly uneventful recovery of the wrecker last week which is always good :-D
Had some time to look her over and have found a few parts I will need, thought someone might be able to help since I looked at the crossover list and it lists several versions of parts in there and I am not sure which is which.
I need to replace the seal on the T-Case that has the drives shaft that goes to the front axle.
I also need to replace the seal on the T-Case that has the driveshaft that goes to the Main Hydraulic pump (large one)
Lastly the front axle seal where the driveshaft connects is weeping too.
Anyone know offhand which ones crossover to the sheet thats a sticky? Those descriptions don't make a whole lot of sense to me.
Thanks in advance for the help.
porkysplace
1,496
mid- michigan
Your best bet is to look up the parts in the parts TM and google the part number . Looking this up will tell you the correct name for the parts you are needing , then you can use the cross reference .
