m936A2 vice mounting plate
juanprado
3,078
Metairie/La (N'awlins)
I believe the M936A2 wreckers do not come with a vice mounting plate. I have seen that m936A2 wreckers have a tray installed on the front of the frame on both sides to hold counter weights.
Has anyone installed a vice plate on a M936A2 with the counter weight tray also installed? Will they both fit at the same time?
Thanks for the feedback!
Artisan
227
CDA Idaho
If it is the same bumper as an M925A1, I have a kit
I designed and had cut w/ a water-jet machine.
It comes in two pieces, you weld the final
piece. (trust me on this, works wayyy better this way
It looks store-bought if you do it right. They are on Ebay.
Search for M939 Vise Plate or CLICK HERE
(my ebay ad so rules say it is ok to link to it.)
I have pics on EBAY, you can see the two unfinished parts
and you can see them welded up and you can see it installed.
SS members get 10% off.
juanprado
3,078
Thanks for the feedback.
Today with GoldnEagle's help we mounted an A2 winch with the counterweight trays ( I will use them for ammo box storage & misc storage) on my m923. The vice plate fit perfectly as the passenger's side counterweight tray only uses 3 bolts on the top and the cut out on the side lets you bolt the vice plate in from the side with no issues.
Looks like some a2's maybe had the vice plate added in the field?
