- 6,862
- 701
- 113
- Stratford/Connecticut
I have found an inexpensive substitute for the Allison reverse pressure switch (which Allison charges 135 dollars for). The part is 416372C1. It is used as a reverse switch in International trucks and I believe on HETs and other larger military tractors. It has 2 terminals on the back, you can solder a pair of female packard connectors without the shell they snap right on and the one I did I filled with rtv silicone and then wire loomed it. I installed it today and it works just like the Allison switch. I ran the wire up into the battery box and I have a relay set up so in reverse the switch closes and gives the relay coil a ground to close the circut and activate the reverse lights. The switch will only activate when reversing with the engine running it works on transmission fluid pressure. There is a bolt on the passenger side of the trans you remove and the switch screws in.
