M998 mirror bracket bolt spinning
BlazeKeeper
Tennessee
Hello,
I'm a member of my local volunteer fire department and we have received a surplus M998 to replace our current brush truck. The bottom mirror bracket on the passenger side won't tighten up. The bolt just spins. I can't tighten it or loosen it. This is the style of mirror I'm working with.
mirror.jpe http://nebula.wsimg.com/obj/MjJEQUU...2MjczNmU4OGNlNzY5MjlkZDBjMDIxN2ZhMDA6Ojo6OjA=
Anyone have any tips or tricks? Is there a nut on the back side that I can get to somehow?
Thanks!
Scar59
42
Mt. Eden, KY
Per the illustration , it looks like the bolt threads into a "rivnut", not a captive nut on the inside. Rivnuts are common in aluminum structures.
Try to grab the collar of the rivnut, not much material there though. May have to apply a little American ingenuity.
May have to pull it out and install a plate nut.
BlazeKeeper
Tennessee
I didn't notice that when I posted the link. The A post is smooth under the bracket, not like there's a threaded insert in there. I'll try and get a picture of it later this afternoon. Or at the very least try and find a more accurate picture.
TedG
39
MI USA
Sometimes you can put pressure on the rivnut and then turn the bolt. Try pulling the bracket towards you, else cut off and start over.
KansasBobcat
9
San Antonio, TX
When installing new fastener put a little anti-seize on the threads. I would rather have to tighten the mirror than install new rivnut. Also some people put some epoxy on the outside of the rivnut when installing.
