M998 to GMV-ish conversion
Jonesy
Port Washington, WI
So in my ongoing conversion, I have recently added a gun turret to my soft top M998.
We used an MG3 rig, that we slimmed down. ( German engineering is nice, but ridden with superfluous features. )
We utilized the existing B Pillar and added bracing supports to the windshield, and C Pillar. The result is more solid than the original configuration, which was a nice surprise.
We spun the M6 pedestal around so that the rear gunner and the turret won't overlap each other, and are in the process of fabricating the GMV side rails, and some swing away arms for the VC and waist gunners.
Below are pictures of the ring install. I'll add more as the rails, swing arms, and paint go in/on. We're also fabricating a new top out of 1000d Cordura that will fit OVER the ring for travel, in Multicam Tropic.
Action
1,561
East Tennessee
See those slots in the windshield frame about 4" - 5" long. That is where the original had a reinforcement plate pushed in for the turret mount to bolt to. Did you put anything inside your windshield frame to reinforce the bolts?
Jonesy
Port Washington, WI
We actually did re-enforce the windshield mounts, with steel plates behind and in front of the grade 8 bolts, and then rubber shock absorbers between the plates and the windshield frame, for vibration dampening. The bolts are on the underside.
We'll be mounting 240s up there- and occasionally shooting a barrett off it when we're feeling saucy.
The top we're fabricating will have a zip off "hatch," so we can retain the soft top appeal.
Action
1,561
East Tennessee
rubber shock absorbers are useless on the windshield frame, because the bolts are against the two pieces of metal.
I'd have to be feeling saucy with that c-pillar holding up the back side.
I wouldn't want to be anywhere near that when firing big guns up there. Be safe.
At least there is some no-slip tape on the tunnel top.
Jonesy
Port Washington, WI
The rubber is there for the potential rattle of the plates. And it fits the bill.
Fear not about the C pillar. It's not holding anything up. The stabilizer bar is just there to keep it from swinging freely while the soft top/door bars aren't on. And it's being replaced with a tubular frame next week when the bed rails go in. (Hopefully)
