MAJOR repair job
solarmon
buttfuk, China
Been hearing an ominous rattle/clank kind of sound from under the hood. . getting louder . . . so I figured I'd best look under there.
The mysterious noise was coming from the area of the steering pump, or perhaps the alternator above it. . .hard to pinpoint with the fan blowing the sound around. Wasn't that typical grinding that comes from a failing pump. .sounded more like something loose. .or mabe a VERY loose bearing. Weird thing was that the sound went away at higher RPMs.
I started by removing the alternator belt. .which made NO difference, so I set out to loosen the bolts on the steering pump to remove THAT belt . .
and. .
discovered that the bolt holding the bracket to the engine block was eight turns lose.
END OF RATTLE
If only all problems were so easy. LOL
PS . . also discovered that my GEM electric car makes a PERFECT work platform for the 1008 . .j ust back it up against the front of the truck . . .a WHOLE lot easier than the usual stepladder.
mudmagnet63
Geary Ok
We have the box of death it's a 2' tall box I built years ago to work on my civvi blazer it's long and not very wide so if you lean in to far it gets wobbly. we have had it for so long now any thoughts of modifying it are out of the question.
mud
sparky1
becket,ma.
mud
my old stand by is is your standard plastic milk crate.you know the one that flips over if you lean to far in the engine compartment.
jimmy-90
Haymarket Va.
That thing would be awesome for putting around inside of the walmart. You should try that and see if they let you do it. I mean some of the super walmarts freeking enormous!!!
solarmon
buttfuk, China
The GEM is street-legal, with a top speed of about 35 (after some tweaking of the controler), and a 30-mile range. .would be a bit of the old overkill in Wallyworld
besides, the nearest one to me is 120 miles away in Grand Junction, CO
solarmon
buttfuk, China
done that milk carton thing. .have the scars on my chin to prove it
also have an adjustable-height work platform. .the bucket of my Bobcat, but it has a leaky hydraulic cylinder (surprise), and slowy tips forward while I stand in it. The GEM is better
319
Lieutenant
3,347
58
Michigan
and. .
END OF RATTLE
Quite ironic! Mine had developed an un-usual rattle in the last few days and I discovered today that this bolt was missing! I only noticed it because the alternator was shaking and you could see the bracket pulling away from the block. Had a bolt in stock to make a quick fix, tomorrow I'll figure out what length it's supposed to be, then buy one and loctite it in.
91W350
57
Salina, Kansas
I found a large cooler filled about half full of water so it does not slide so easily works great. Sure beats trying to balance on my toes on the locking hub.....
