MEP 1030A
Robert P
Ca
New to the forum and military generators, I have a new to me MEP 1030A that the DCS screen has no actively, nor does the fuel pump turn on, the breaker has the correct voltage when switched to the off position and it will crank with dead crank switch. I believe the DCS is faulty and opened it, it was pristine without any sign of visible fault or damage, checked the connections while it was open and everything seemed properly landed and secure. Batteries are new and correct duel 51r cables are tight and no damage found anywhere, before I buy a new DCS any help would be truly appreciated.
DieselAddict
2,337
Efland, NC
If you do need a DCS, Kurt has a couple available.
