I have been working on a MEP-803a I bought from auction that had a number of issues. Most of them were electrical, broken or missing parts. All those have been addressed and still can not get it started. The Metering Pumps were replaced and installed incorrect, I have fixed that. The front gear covered was removed at one time (covered in RTV), I am thinking as part of the metering pump replacement.
The problem I am having now even with the metering pumps installed correctly the start/stop level will not rotated clockwise (to the start position) once the fuel solenoid engages and pulls back. It will rotate if I move it myself, it not stuck. Looking at various online video the start/stop level appears to rotate clockwise on its own once the fuel solenoid moves back. Even when I remove the solenoid arm from the lever, it will not rotate on its own. I removed all the metering pumps to make sure the rack is not bent or hung up, it will move easily on it own and you can tell it has spring attached to it, it will move on its own from front to back of the engine with no effort. However the level is not rotating by itself even when the rack is moving.
Before I open the front of the gear housing cover and start looking inside I wanted to make sure I am not missing anything. The first picture the specific parts I am talking about. 45 is the lever which is connected to part 43. and it looks like spring 41 is also connect to it. I believe this spring is what should rotate the lever clockwise. It also looks like part 43 engage the rack for the metering pumps. The second picture is an internal shot of the part 43, I put a scope into the engine to see what was going on. If you look it appears to have wire wrapped around it, and it not the same thickness as the spring 41 you can see in the picture.
I attached a link at bottom to a video I record of part 43 rotating, I hope you all can view it, its MPG4. It will allow you to down load the video to your computer. If you look at the video, it appears like the spring is not moving so it not attached to the level 43 as I think it should be. There is also spring 38, the drawing does not show where that is attached, that could be the wire seen on lever 43.
Let me know what you think. Could anyone share a good picture of proper connection of spring 41 and lever 43 should be. As said I am thinking this was not put back together properly when it was worked on.
TIA
share.icloud.com
TIA
iCloud Photos - Apple iCloud
View, organize, and share photos and videos with iCloud Photos on the web. Changes will sync across your devices with iCloud.
