MEP-805B parts free for postage
Don+23805
13
Central VA
With lots of help from some forum members, I replaced the control system on our MEP-805B. Some parts (like the CIM) have already found new homes. What's left, and available for the cost of USPS Flat Rate box postage, are the backplane, I/O Module, Sync CT, the Sync Load Sharing module and the triple CT. These came off a working set that suddenly quit after about a year. First thought was that it was out of fuel. No such luck. With lots of assistance and encouragement, I finally replaced practically everything except the main contactor and engine control switch. No guarantees, but it all used to work fine. If interested, contact me offline at RadioPrinceGeorge at gmail dot com
Don
jmenende
416
Puerto Rico
Don
I sent you an email.
Don+23805
13
Central VA
Here’s an update on my (brother’s) MEP-805B. Early on (this goes back to December) I received LOTS of help from members of this forum, and a number of inquiries about this “project”.
Brother Rich bought the unit as backup 3-phase power for his business, not as an historic restoration project. He used it for about a year, and then one day it just quit like it was out of fuel. Being the family go-to guy for all things electrical, I got recruited. Bro’s business partner Hank is a good engine guy. When I got there, they had already checked out the fuel actuator and decided it wasn’t getting any power even though the wiring seemed OK. I hooked it to a variable power supply and we immediately got the engine started, so Actuator was OK. I called GAC and they said the MPU magnetic pickup should put out at least 1 volt when cranking. Tried that and nothing! Checked MPU continuity and it was open. They sold me a new one for $108, but due to UPS snafus, it got lost. So try Amazon. Same dimension and thread, they had it for $32. Refused UPS delivery a week later. Made in China, it put out >7 volts. But still no action from GAC speed control. Thought maybe the new 7V signal fried it. But it said it accepted up to 120VAC. GAC estimated a replacement was around $1K, but I could mail my unit to them and they would evaluate (not fix) it for $100. Above budget! Back to Amazon. They had what was probably a counterfeit unit with barrier strips, not plug-in to the backplane for $45. Didn’t even change the GAC ESD5500E model number! In fact just copied the GAC documentation suggesting that I call GAC’s tech support if I had any problems. Mounted it (see pix) and it worked right off the bat. Deere ran, but no volts. Steel Soldiers to the rescue! Hooked the trusty variable supply to the field winding and plenty of volts. Voltage regulator was also GAC but I wasn’t going back there. Found a “Marathon compatible” Fuerdi AVR SE350 unit for $27. Thanks Marathon for the documentation. Works great. Found that the speed control even had the loop tuning pots correctly set. Ran at 58Hz, but a quick tweak got it 60.
Bro had initially asked if we couldn’t run it without the PC. My read of the TM had the PC too involved to dump. With forum help and rereading of the TMs I was getting to the point of thinking the CIM could go. So we now had a working Deere and were making electricity. Looked at a 3 pole circuit breaker but no good bargains. Forum advice indicated that a normal CB wasn’t fast enough to protect the generator against a possible short. The way they reacted quickly enough was to have the CIM monitor current and dump the output contactor. CIM now gone to a new home. Went to eBay and found 3 “removed from equipment” 5 amp trip relays for $25 each. Replaced the 277:1 triple CT with three 200:5 CTs from Amazon for $16 each. Advice was that the Army was so conservative that this 30kw unit could probably be pushed to 60kw. If any of the relays hit the max (adjustable) it dumps the engine and output contactor.
So what about instrumentation? Back to Amazon. Turns out the 805B fuel level transducer is some sort of standard and found a % fuel level indicator that matched for $24. Also got three volt/amp (with their own CT) readouts for $16 each. Added another volt/frequency readout hooked to L1-L3 for $14. Added a water temperature readout for $17. An oil pressure readout was $26. Also added a low oil pressure cutout switch for $18. The old spring-return Reset toggle switch was wired across the oil pressure switch so you hold it while starting until pressure gets in the OK range. Also put a plain old ammeter in the alternator charging line.
What have we lost? You have to hold the oil pressure bypass switch to start. You don’t have a first-in alarm system. It just dies and you have to figure out why. There’s no low fuel warning. If we use the auxiliary fuel pump for refueling, there’s nothing to keep from over filling the tank. Over temperature doesn’t kill the system, but expert advice says that would be a plus. Easy to add. About $400 in parts now has what seems to be a reliable backup power source.
Some of the business plan has changed in the last half year. The current plan is to provide backup power to a 5 unit trailer office complex. We tried it on a 2-unit portion and when the A/C went on the 805B didn’t even hiccup. Project declared a success. Any questions cheerfully answered. All leftover pieces have gone to new homes.
Don
loosegravel
Just a retired mechanic who's having fun!
504
893
Enumclaw, Washington
Don
Dude! Talk about getting to know your machine wow! That's called getting very intimate with a generator, probably way more than you wanted to I bet! Thanks for sharing your experiences though. I recently acquired a MEP-805B from auction. I had a gut in Portland who wanted to buy one of my MEP-803A's until his electrician told him he needed something larger for his needs. So I told him that I would bid on the two 30kw's that I saw coming up for auction and I won one. Now he hasn't been answering my messages so...:unsure: It's a great runner though. I was able to load test it up to 125% using a brine tank. (Check previous posts if your curious) It's a great way to put a load on these things. I was a little leery of doing this on something this big, but it worked flawlessly. Thankfully the screen is all good too. Just a little over 1100 hours on the meter. I'm sure that I'll find a good home for it.
Jeff66
ny
Don
Jeff66
ny
Don
Hi,Great Job, Do you have the stock fuel level sending unit? or do you know where I can get 1 ? thanks J
peapvp
1,581
Basehor, KS
Congratulations, this is for sure a lower cost alternative and would work with our regular auto / remote start system
We were asked if we could design a replacement control system several times and had to decline since everything we manufacture and sell is made here in the US and cannot compete with the parts you incorporated.
Again, great job
Don+23805
13
Central VA
We had the stock 240 - 33 ohm sending unit intact, and found that this is some kind of standard. Amazon had an inexpensive digital readout that was compatible. Just checked amazon and they offer the sending units in a number of different lengths, again at bargain prices.
Don+23805
13
Central VA
