MEP 8xx A/B Replacement Relay Type KUP NSN 5945-00-458-3551
peapvp
1,461
Basehor, KS
If you are looking for KUP Relay NSN 5945-00-458-3551 for your Genset then you got two options:
1. If you needed them yesterday and can live with the Civilian (TE Connectivity / Tyco made in China Version )
then your best bet is Mouser, Digikey, Arrow, Allied Electronics etc.
Part Number: KUP-14D15-24 or 1-1393118-4 (Both the same Relay, first part# is original P&B Part Number, second Part# is Tyco)
Digikey
2. If you want the NSN 5945-00-458-3551 original Version which is now made in China/Mexico by Tyco then you can get them on our Website
These are Pre-Order only and have a 3 to 9 week lead time as they are tested in the USA to MIL-STD by Tyco before shipment
(certified conformance)
INOVA HIGHTECH
Thank You
peapvp
1,461
Basehor, KS
That is correct, however those are all the same Relay
Potter&Brumfield sold their operations in the 2000's to a subsidiary of TE Connectivity which then sold out to Tyco sometimes around 2009-2011
Hence, depending who made this Relay at what time resulted in different NSN's which are all exactly one and the same Relay.....
Check NSN #. I believe it should be 5945-00-458-3351
Part number search on KUP-14D15-24 results in 4 separate NSNs......
https://www.parttarget.com/sku_KUP1...4&callid=b25d7d31-7468-487d-bdf1-ed43c60122bd
Guyfang
26,263
Burgkunstadt, Germany
There are currently at least 8 NSN's
5945-00-458-3351
5945-00-194-3615
5945-01-026-6657
5945-01-136-6961
5945-01-212-2000
5945-01-240-2272
5945-01-243-3974
5945-00-408-0727
And 21 part numbers for this relay. Unless someone REALLY just has to know, I am NOT going to list them.
472 OHMS NOMINAL is a good relay coil winding.
I have seen this relay in the MEP-8** series set, Two different heaters, Two different welders, and also used in several different load banks. There is a list of about 35 different systems that use this relay. THAT'S why the military ordered so many last year.
