Mep003 gages dont work
jamawieb
575
Ripley/TN
Take a meter and see if you get a reading on the connectors of the voltage gauge to make sure the generator is producing power. No output, no readings.
csheath
215
FL
Yep, make sure you have output at the lugs and go from there. If it has output then the gauges are bad.
If they are the same as the gauges on an 803 they CAN be taken apart and cleaned out but they won't be accurate. Order some inexpensive digital meters and convert it to something usable.
1,187
Is the control panel connected?
