azreark1
- 8
- 3
- Dallas, TX
Hello group, my partner snagged a MEP0114A GPU for me to fix and get running (was retrofitted with a 28v DC starting unit for aircraft by Hobart for probably the Air Force, the Hobart tag has a contract and NSN number). He purchased from an airport FBO that had it sitting in their boneyard for a few years because "it didnt work anymore" and that was about all the information they gave me on it. I slapped two new batteries in it, it will start up but struggle a little bit, like there's no fuel pressure/fuel flow.
Low pressure oil light is lit on the main panel, i plumbed a gauge in to the engine to verify pressure and there's 60psi at idle. I couldn't hear the lift pump running with switch in RUN, so applied 24v directly to it and it will sluggishly run but wont make a difference on how the engine runs, my next step is to change both filters since i don't know how old they are, but i'm wondering is the Low Oil Pressure fault trying to kill the engine? Running in Battle Short doesn't change how it runs.
So that's problem number one, getting it to start and run consistently, problem two is no generating juice. When i move the operation switch from IDLE to RUN, it doesn't always rev up to operating RPM so i'm thinking the switch needs to be replaced? Will test that later, but it is a Mode II genset so it's all controlled electronically.
I'm trying to dig into the manual but it's a lot and my partner(he's a business guy, not a mechanic) wants this thing operational ASAP, but at a minimum wants it properly diagnosed as soon as possible, so i want to come to all of you in the community with way more experience in the genset for help, rather than comb over the manuals for options that may or may-not actually fix or help fix the problem. I have a regular full time job and this is on the side so can't really spend my whole day combing through manuals and testing.
So for now, two things, consistent start/run cycles and genset field excitation. It's an old military diesel so theoretically, as long as that injection pump has fuel flow that engine should run top notch (and when it's running, the thing sounds mint)
Oh and the airport FBO we bought it from decided it needed to be white (i guess back when they bought it) and removed the data plates on the outside of the MEP unit, so all i have is the engine tag.
EDIT: Thanks for helping me with the 114A identification.
