Mk48 Trailer Loadout w/o FPU?
Augdog1964
15
Richmond, IN
Hey all,
Has anyone ever bought a Mk48 trailer w/o the FPU in CA? I need to get a bid on moving one, and I think its a little more than a standard pickup! LOL
Thanks!
M920
30
chama/nm
Hey all,
Thanks!
Ok so the Mk48 is actually the FPU! I assume that you are asking about hauling the RBU without the FPU correct?
So as an example, the Mk18A1 RBU (self loading container hauler) weighs 20,100 pounds empty and can be towed on it's own wheels by using a pintle conversion kit. It attaches to the front of the RBU and turns it in to a pintle hook, bumper pull trailer.
So you need a pintle hitch adapter for the RBU and at least a 5 ton or a commercial size truck to pull it with.
Btw, the tow hitch bolts on to the trailer and you have to remove the rear driveshaft, so make sure you bring tools.
Also, you need a cord for the lights and two coiled air hoses. Be prepared to splice those in to the trailer since it has plugs that are made to only go with the FPU!
73m819
328
gainesville, ga.
Why not get a BIG rotating wrecker, just lift and load, this is pretty much how everybody does it, how we did it in FL., if you have access to a loading ramp, you could cage the brakes and have a fork lift work it onto the trailer, this would be a hassle but doable.
Hoefler
21
White Bear Lake,MN
Go to the thread-duece tows a MK18. Sandcobra recovered my MK18 which is basically an MK14 with stuff. Used a wreck to lift on to trailer and off as well. I got a towbar with mine along with gladhands and trailer cord. One it arrived and was unloaded, I was able to move it around with my 5-ton.
Not the easiest recovery but worth it.
Pete
