Most Popular Engine, and Transmission Swaps: ???
Prankster
Ponca City, Oklahoma
[FONT=&quot] [/FONT]
[FONT=&quot]There seems to be some talk about the OEM Engines, and transmissions installed in the Deuce.[/FONT]
[FONT=&quot]I haven’t read anything about people doing any conversions yet so I thought I would just ask. [/FONT]
[FONT=&quot]Hey!!! Any of you doing any great conversions??? [/FONT]
[FONT=&quot]I have seen the Bob Jobs, the disk brakes, and paint; then there is wheels, and tires, and I think all that is awesome; I was just wondering the power to fuel ratio.[/FONT]
[FONT=&quot]I came across this web page, and I Like the Horsepower, the Torque, and the Fuel Mileage.[/FONT]
[FONT=&quot]The Information here states that it is too much power for any on road use. Then again, he isn’t driving a Heavy old Deuce![/FONT]
[FONT=&quot]1966 Ford Bronco - Diesel Power Magazine [/FONT]
[FONT=&quot]Once in a while, we here at Diesel Power run across something that just makes sense. When we saw Chaz Lightner's '66 Bronco, that feeling hit us. We knew the 4BT Cummins that powered the Ford had more than enough torque to propel the beast on boulders and trails yet still achieve excellent fuel economy. The fact that the swap was cleanly done-with excellent ideas and execution-was simply icing on the cake.[/FONT]
[FONT=&quot]The idea behind this swap first started after the wicked-quick throttle response on the 520hp, 408-cid Ford V-8 that was in Chaz's Bronco led to a spin after trying to pull into traffic. He wanted something to match the torque of the 408 while being a little less temperamental. He wasn't so crazy about the 7 mpg he was averaging either, so the idea of the 4BT swap was born. Mounting of the engine itself required minor notching of the frame (for turbo clearance) but not much else in the way of custom fabrication. An NV4500 transmission was sourced and mounted behind the Cummins with little trouble.[/FONT]
[FONT=&quot]We get questions about the 4BT from time to time, so let's talk about the engine. A call to Turbo Auto Diesel and a talk with Ken Diaz convinced Chaz that a 400hp four-cylinder would not be a problem, and Ken delivered. The Cummins in Chaz's Bronco is one of the first 4BTs we've seen that has been highly modified, so we made sure to dig as deep as we could on the details.[/FONT]
[FONT=&quot]For starters, the engine was rebuilt, balanced, and blueprinted to ensure vibration-free operation by Beck Racing Engines in Phoenix. The head received the usual high-horsepower, 12-valve treatment and was fire-ringed and machined for 14mm ARP studs to handle some serious boost pressure. A 12-valve lift pump was used, and a four-cylinder P7100 pump built by Turbo Auto Diesel was used as an injection pump along with marine injectors. Vortech helped Chaz design an air-to water intercooler (complete with a small radiator to recirculate and cool the water for the intercooler), and his good friend Ray Bong helped test-fit the engine 17 or 18 times in the Bronco's chassis until they got it right. As far as turbos, there have been many-the first providing an outrageous 453 hp and 712 lb-ft of torque at the wheels and 88 psi of boost pressure. The engine, however, proved almost undriveable with this turbo, not making full boost until 3,000 rpm and defueling at 4,200 rpm, only leaving about 1,000 rpm of useful powerband. Eventually, a compromise was reached, and the engine was detuned to about 350 hp while remaining torquey, driveable, and fuel efficient.[/FONT]
[FONT=&quot]Even though Chaz has more than 400 hp (crank) on tap, gets 25-28 mpg, and can even run on biodiesel or vegetable oil, his '66 Bronco has even more mods in store for it. Right now, he's switching over to a 4R100 automatic transmission with a custom-built Sun Coast torque converter designed to always keep the engine under boost. He's also looking at adding A/C to keep him as cool as his custom ride. Now that Chaz has taken the steps to create an awesome 4BT swap (he took First Place for best engine swap at the DHRA Vegas Nationals), we hope to see more four-cylinder swaps out there. Almost 30 mpg and 400-plus horsepower in these times of high fuel prices sounds like a good idea to us.[/FONT]
Prankster
Add-on Transmission Information
[FONT=&quot]
[/FONT]
[FONT=&quot]Ford Super Duty 4R100 Transmission - Four Wheeler Magazine[/FONT]
[FONT=&quot]When it comes to heavy hauling, most people would agree that the Ford Super Duty platform is probably the most favored of the bunch. Since its inception, annual sales have been staggering at over 200,000 per year. This equates to well over a million Super Duty trucks in service today. The bulk of these were equipped with the 7.3L Power Stroke diesel option, and the great majority of these came with the time-tested four-speed automatic known as the E40D or 4R100. This transmission was suitable for stock power levels (and end users who do things by the book), however, once overloaded or exposed to increased torque loads, both the E40D and 4R100 quickly showed signs of weakness.[/FONT]
[FONT=&quot]That's why we did a little investigative work to see how these transmissions could be configured to perform reliably under even the most demanding conditions. Our search led us to John Wood Automotive of Holtville, California. Wood started building Ford transmissions in 1983 and prides himself with a reputation for utmost attention to detail and customer satisfaction. Wood operates his business on the principle of quality before quantity, which with only one assistant requires he take on only one transmission rebuild per day. This methodology pays off, as most of Wood's patrons are referred by word of mouth. Diesel drag racing, sled pulling, sand-dune running, and heavy towing are the primary lifestyles of Wood's customers.[/FONT]
[FONT=&quot]Wood has an intensive educational rebuild program that's set up to teach Super Duty owners all the ins and outs of their transmission in one full eight-hour work day. Some customers take notes while others take a rain check and visit the nearby Glamis OHV area, but everybody leaves happy knowing they have the most efficient, reliable, and robust E40D or 4R100 money can buy.[/FONT]
[FONT=&quot]19. Each and every transmission Wood rebuilds also receives a brand-new factory Ford radiator. This is always necessary because, once contaminated with clutch material, it's almost impossible to get the same efficiency from the built-in transmission cooler. In the case of '99 trucks, Ford didn't include a built-in transmission cooler with the radiator. This is part of the reason why they had that silly bypass circuit with the check valve shown earlier. In '00-and-later trucks, they improved this design and included a separate circuit for ATF temperature regulation at the bottom of each radiator. This design helps bring the ATF up to normal operating temperature at initial start-up. It also helps cool the ATF under extreme conditions.[/FONT]
[FONT=&quot]Another service John Wood offers his customers is custom ECU tuning via SCT's performance interface and computer software. We had him tune our donor's truck for improved power and higher top speed, as well as speedometer calibration settings for 40-inch tires. In addition, this software can take out power for improved reliability in fleet trucks or set a speed governor for teenage drivers. Our donor really liked the performance gains this retune provided for his truck. In fact, it worked so well, he decided to get rid of the plug-in tuner that caused his troubles in the first place. After over 1 1/2 years and nearly 29,000 miles on the Wood-prepped transmission, our donor is very happy and still enjoying his Super Duty's newfound reliability and performance. The cost of this rebuild was not inexpensive, but considering what you get for the money, we feel it's one of the best programs available for the 7.3L Super Duty owner.[/FONT]
[FONT=&quot]For those of you who don't need to spend a fortune on transmission performance like our donor did, but still want to tow reliably with up to 350 hp, Wood has an option for you too. This year, he came out with a new rebuild program where he guarantees his work for 75,000 miles or three years, whichever comes first. This program was designed for the average Joe who simply has an intake, exhaust system, and/or a programmer. The price for the Towmaster rebuild is $3,600-not bad, considering the average dealership rebuild is around $3,800.[/FONT]
[FONT=&quot]Read more: http://www.fourwheeler.com/techarticles/drivetrain/129_0710_ford_super_duty_4r100_transmission/viewall.html#ixzz1XmrLnSOG[/FONT]
[FONT=&quot]
Read more: http://www.fourwheeler.com/techarticles/drivetrain/129_0710_ford_super_duty_4r100_transmission/viewall.html#ixzz1XmrDAUE7[/FONT]
1,187
Sounds like a good topic for the deuce modification forum.
