dilligaf13
- 33
- 28
- south, florida
It's pretty much a plug and play replacement. Check the TMs for torque specs on the mounting bolts. If I remember correctly there's a thin gasket that mounts between the compressor and block you'll more than likely need to replace. Other than that it's a pretty strait forward replacement. The second set of hands will be useful because the compressor is on the heavy side and mine was a PITA mounting up by myself. Good luck and have fun.
