Napa Part number Hub Seal
1,187
Front and rear inner wheel bearing seals are the same part.
Rear also has an outer seal.(not used on the front).
Both seals are only available as "military parts", NAPA does not have them.(they are a special application seal, aka. non standard)
Goggle 2.5 ton Rockwell axles parts, and you will find "shops" that have them on line.
gimpyrobb
dumpsterlandingfromorbit!
27,787
776
Cincy Ohio
Are you asking for the INNER inner seal? The gear oil seal? That one is not the same. How far down did you tear into it?
