need alternator bolt
trooper632
Utopia, TX
Hello all, I am in need of a cucv passenger side long alternator bolt. The M1008 I bought didnt have any alts, and the only bolt I cant find anywhere is the long bolt on the bottom of the pass side alt . Any leads on where I can get one or buy one from someone would greatly be appreciated.
K9Vic
Fort Worth, TX
Do you need the spacer behind the mount also??
I would highly recommend it, I have seen the trucks with out them, but that spacer is designed to keep the alternator from moving in. So you should have it there to help stabilize it against tghe engine block. If you cannot find the part, most fastener stores have a like tube spacer, just get one that is the closest and use spacers to compensate the gap.
Warthog
240
OKC, OK
I understand that you need a bolt, BUT with the thread title and your "need", this thread belongs in the Want Ad forum, not the CUCV Forum.
Want Ads are not allowed in the Open Forums.
By the way it is a metric
M10-1.5 - 169MM
http://bolts.tpub.com/252/01-150-9493.htm
