Need Brake Part Number or Source.
1,540
62
Riyadh, Saudi Arabia
I need the part number of a squared 90degree brake fitting that connects to the front wheel brake cylinders. Its almost like a banjo fitting. The flexable brake lines screw into it, and it has a bolt that goes through it into the wheel brake cylinder.
Also anyone know the part number and a source for new ones?
The reason I need a new one is the one on the truck is stripped out. I believe it was repaired because the threads the stripped out of it were of a different metal then the part itself.
And yes I tried a search, but as I don't know the correct name or term I couldn't find and relevant info.
1,192
Best price is not improtant, if they don't have it in stock!
Call Memphis Equipment, they most likely will have one.
If not, Try Clark Equipment.
The list goes on...
rlwm211
19
Guilford, NY
I was going to point out that the new wheel cylinders I got and installed had new blocks with them. I went out to look for them and apparently I tossed them, never thinking someone would need them.
The brand of Wheel Cylinders I got were "STAR". I know this is not helpful in that I am not sending you the part or the number, but if you happen to replace wheel cylinders, you probably will get the adapter blocks that convert the Banjo style attachment to the wheel cylinder itself to the flare line of the Steel brake lines.
RL
1,540
62
If it was my truck I would be replacing ALL the brake cylinders and all the lines with stainless hard lines and braided stainless flexible lines. But it is my Father in laws Deuce, and im just trying to get it fixed again so we can drive it. Im actualy being nice and installing a wilwood remote brake reservoir. I'm telling him its his upcoming birthday present. So far I have over 220 dollars invested in new front stainless braided lines, gallon of dot5 fluid, remote reservoir, pressurized brake bleeder, and various fittings.
