Amxhunter
- 0
- 0
- Mobile, Alabama
Let me start off saying that without the help of this forum i'd be in trouble. So a big thanks.
I need some help on this install. I had started a previous thread about progress but we are beyond that issue at this time and i will update it when finished.
The mechanical part of the install went OK. however I'm having the following issue.
1. I installed the 5 ton pump in the deuce , bolted right in.
2. I installed the PS Box similar to others , on the inside frame channel and it worked out OK.
3. I plumbed the pump to the PS box (HS54 box) as i think it should be with pressure from the pump going to the bottom port and the return coming out the top of the box going back to the reservoir.
Is this correct ?
The Problem I'm having is that the box does not want to turn right.
It turns to the left just fine.
It comes back to center fine.
It does turn about 1 round to the right with a firm effort, then gets really hard to turn but does move .
I notice that when I turn the wheels to the left, at full stop I can hear the pump bypass.
This does not happen when turning right. At any time.
Disconnecting the drag link, the box will easily turn stop to stop, and swings further than is needed for normal steering, so I know it's not hitting the internal stops when turning right.
I would appreciate any feedback or questions. Been working.
Is this correct ?
