Need Help With Engine RPM Signal For TCM
mynewtoy
West Pittson Pa.
Hello All
Can someone point me to a Thread that talks about different methods to pick up an Engine RPM Signal for the TCM on my 4L80E Swap? I have the MSD TCM already I'm wondering if anyone has dealt with this yet.
Thanks In Advance
nyoffroad
718
Rochester NY
Not sure if this will help but my after market tach picks up the engine RPM from the alternator, all it is is a small wire that runs into the back of the alternator thru one of the vents and attaches to any ONE (just one) of the positive diodes.
Keith_J
1,327
Schertz TX
Stock CUCV alternators have a tach signal connection. Depending on transmission control module, you may need signal conditioning. Dakota Digital has a module for this purpose.
1,823
On the HMMWVs they have a unit in place of a vacuum pump that sends some type of signal. Might be worth looking into.
Keith_J
1,327
Schertz TX
Can you send me a picture of what I'm looking for?
My finger is pointing to the terminal that is for the tach module buffer. It is a snap on boot. Driver side alternator. This is an alternating current with frequency proportional to engine RPM. The Dakota Digital module will convert this to a tach level signal of pulses per revolution which is adjustable. 20210302_073934.jpg
Barrman
2,035
Giddings, Texas
As pointed out the CUCV alternators have a tachometer signal already. Some vacuum pumps generate a signal as well. But, that signal might or might not talk to your tachometer or TCM.
Your transmission control module should generate its own engine speed signal because it gets the input shaft speed reading from the sensor inside the transmission. At least my Compushift TCM works that way. However, it won't export that signal to a tachometer or its own read out.
I have used the Dakota Digital converter box to go from a CUCV alternator to an Autometer analog tachometer on my M715 with a CUCV engine and dual alternator set up. I also used a Dakota Digital converter box on my Cowdog Suburban project. I have a Delco CS130 serpentine belt alternator on that truck and used the Dakota Digital box to get a good tachometer signal to my gauges and for read out on the TCM display.
If you get a diesel pulse adaptor for a digital timing light with RPM read out. That will give you an exact engine RPM that you can adjust the Dakota Digital box to get your tachometer exactly dialed in.
A Snap-On MT480 or MT1480 "Lummy Mag" timing set up will also give you an exact engine rpm from the slot in the harmonic balancer as a baseline to set your tach or TCM.
Barrman
2,035
Giddings, Texas
I was typing while you asked your question about the stock CUCV tach signal. It was for the STE/ICE diagnostic suit case they used back when the trucks were new. Think all analog OBDII with no real information from a 4 digit digital read out. I went to the trouble to find one that worked and used it once. It is now a novelty in my opinion for these trucks. However, the adaptors that come with the STE/ICE can be used to check all kind of PSI readings with real gauges attached to them.
chevymike
481
San Diego, CA
Or you can use something like this optical tach, which is what I used to set the RPM's for my Speedhut diesel tach. Worked great and is cheap.
Keith_J
1,327
Schertz TX
Certain transmission control modules use both engine tach and transmission input shaft speed differential to delay torque converter lock up when there is slip in the converter. If the engine tach signal is not calibrated correctly, it can prevent TC lock up or create harsh lockup.
Barrman
2,035
Giddings, Texas
It is certainly evident who has made a 4L80E work in a truck it wasn't meant to and all we learned making it work. Neat to read about different ways to do the same thing too.
mynewtoy
West Pittson Pa.
I have been reading and searching just thought I’d pick some brains before I dug in. The oil pump drive with the engine speed sensor is expensive which I’d buy if someone could tell me if it would work. I even called MSD but the tech wasn’t very helpful. Im going to try again and hopefully get a more knowledgeable Tech.
Barrman
2,035
Giddings, Texas
I forgot about the oil pump drive way. I had one of those and tried it first. It leaked oil out of the plug housing when I test ran the engine. Then my serpentine belt drive vacuum pump froze up soon after. I went with a CUCV vacuum pump and promptly forgot all about the speed sensor back there. The Dakota Digital converter box for the alternator signal was a lot cheaper than a replacement cam drive tach signal generator and I haven't looked back.
1,823
I have one of the oil pump drives but the sensor is gone. It looks kinda like a tach cable could be adapted. One day I'll follow up on that. Cable drive tachs are vintage neat.
NDT
7,142
Camp Wood/LC, TX
One other way to do this would be to find a junk 96-2000 6.5 with automatic in a wrecking yard and pull the timing cover and whatever attaches to the crank (reluctor?) and transplant it for a factory set up.
