Need help with spring ends asap
Awesome Possum
Central Texas
Texas heat has finally broken and me and Badga have gotten a HUGE amount of work done (at least for us) in the last two days, but now we need a bit of SS knowledge. Just found out I have Badga for an extra day tomorrow so have to throw a work schedule together real quick.
We have the deuce front springs placed for the rear axle, and the mounting holes on the sides drilled and bolted on. Tomorrow we need to drill the holes for the bottom of the mounts. The problem is removing the leafs from the mounts in order to drill these holes. Looks simple enough, but this is usually when I get in trouble.
I hope the stuff I added to the included pic can be seen. I figure A & B ( retaining bolts) can be removed, and then C is driven out towards the center of the truck (in the direction of the blue arrow). I'd use a socket to protect the zerk fitting when tapping it out. The other end of "C" has a slot in it as if it was for a big screwdriver. Do I need to know anything here?
I've seen the mounts bolted to the frame both with and without washers. What's the verdict? How about lock washers? All will be grade 8.
ODdave
41
lansing michigan
Correct on the pin removal, it should go either way. As far as lock washers, No. I would opt for a "top-loc" style of nut insted, preforably in a flange style with a flange bolt. no washers to move around and no lock washers to deform and work there way out. 2cents
Also, FWIW, I would only remove 1 hanger and use it for a template for all 4 spots. Then put it back on the spring and bolt them up. I say this because those pins can be a pain to get back in if anything is tweeked or deformed just a little.
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
Yes, remove the bolts and the pin can be tapped in toward the driveline or out away from it. I would think washers would be overkill, but I would probably use them.
MrM4
21
Wall, South Dakota
Why not use alittle paint to mark the holes and unbolt the side bolts and roll the axle ahead and back, that seems much easyer then tearing down the springs. If theres not an axle on it yet use the paint to mark the holes and just unbolt 1 end at a time and let it swing to the ground.
Awesome Possum
Central Texas
We started with the holes being drilled through the side of the frame, with the clamps holding the mounts and springs in place. We bolted the mounts to the frame, and swung an end of the leaf spring down, one at a time, then drilled the holes for the bottom bolts. Tearing down the springs was actually pretty easy when using that harbor freight crane.
