If you're looking for a civilian or parts store number, forget it, they don't exist. Also, if you're leaking gear oill there you have some other issues. The bearings on the M44 series are lubed with GAA (grease). There is an outer seal where the wheel bearing nuts are. Chances are good that this failed or the keyway behind it wasn't sealed which allowed gear oil to get into the bearings. Another possible cause for this would be clogged axle vents so check those as well. That inner seal was just never designed to retain gear oil so don't expect it to. Oh, the outer seal has no civilian interchange either.
