- 3,286
- 3,460
- 113
- NORTH (Canada)
Block surface checked for flatness, factory-new heads, new-style headgasket (latest).
Non-TD block. Torqued in stages up to 130 ft.lbs.
During second hour of operation I wailed on it a bit more. I noticed ok EGT (1100) but the turbo happily boosted to 15 psi and a bit beyond. I eased up and that was that.
Befor this run, the heads were bone-dry. After this run there is a clear track of oil from the passenger side head gasket.
No active leak. No running issues or weird noises. No oil in coolant.
Should I re-torque right away (had not planned on retorquing new style gasket) or turn down the fuel and chalk it up to experience?
Chances that damage occurred?
