New soft top missing hardware
JCKnife
46
Kentucky
I bought a new soft top on ebay and it does not have the plastic clip along the front edge nor the inserts for the side locks. Are these parts available anywhere?
Hmm, just re-read the auction and found this: "tops were made in 2005 in vinyle, and rope slides not the plastic slides that breaks"
I didn't see any "rope slide" just the fabric of the top itself but I will check again on Saturday (it's at my office).
combat32
107
Booneville AR.
If it is the rope slide/type it will have a small diameter rope sewn into the front edge, you have to feed it through the channel on top of the windshield, a real PIA but lasts longer and stays better when you get it in there.
rrrr
Missouri
To help it slide through the channel make sure the channel is clean. Also, find a small brush and brush vasoline in the channel the best you can. Then put vasoline along the rope section of the top to aid in it sliding in the channel. Good luck !
This technique has been very helpful installing tops and new glass in military windshield assemblies.
swbradley1
Modertator
1,939
Dayton, OH
What might work better than Vaseline is to use silicone spray that they use for camper slide-outs. You can even use food grade silicone spray.
1,193
What does an M37 top have over the door windows? Maybe it's for that.
maxxplanck
Fowlerville, Michigan
JCKnife, boy I'm glad you put a pic up yesterday I recived one of three I ordered all from different people ( 2 camo, 1 tan ). I was kinda worried when the box came it was smaller than the camo ones and when I opened it 2005 top it was the same as yours. I bet we ordered from the same person out in CA ?" I hope it works better ? :neutral:
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
Thats how the old canvas ones were made. Since everyone complains about the stitching failing on the plastic channels sewn on, maybe this is a good thing!
