New starter still no start?????
REDWOLF
Risingsun Maryland
Well finaly had time to put the new starter on. After the problem i had with shorting out the starter silonoid. Hooked the bats back up and nothing, well i have dash lights, but nothing from the starter. The wait lite comes on and goes out after a bit but the starter does not even click. Turned the hedlights on and hit the key and they stay on. Checked the bats and they look good. The gen lights go out when i hit the key but the other lights that used to go dim due to the short stay brite. Need to get it fixed this is my only transportation for work other than the wifes car and she needs it for work. I am guesing there is a fuse on the ignition somwhere? Please help. Any ideas? aua
burbn10
Lake Villa, IL
Check your engine ground straps and your battery connections. You could check your fuses under the dash by the emergency brake too. Could be an ignition switch too. Get a 24v test light and hook it to the starter ignition terminal. Turn the key and see if it lights up. If it doesn't, may be a bad solenoid again.
beanman1
in the south
ok there is a relay under the dash about where the ashtray is that is about 2 inches long and an inch wide you can jump that from the red wire straight acroos to the purple wire if it works you know what you need to get next if still nothing check on the starter if it is grounded good and also on the starter solinoid look to see it there is another place where the small wire can connect because my new starter has two places one works other one doesnt
burbn10
Lake Villa, IL
Forgot about that. Those are prone to failure on these trucks. Had a brain fart. aua
REDWOLF
Risingsun Maryland
Thanks. Some things to try this week end. Also the new starter i got is a new style gear reduction doe anyone now what the stater brace looks like for the new style staters because the old style is to long. Or do you just not need one due to lighter new starter, but they give you a lug to install one. Also is ther a part number for that relay and where to get one?
beanman1
in the south
any chevy dealership should have the brace and it is need do a search on here we have the part number somewhere that how i got mine the relay is actually a ac relay i think the part number is ac40 dont rember off hand if it the gear reduction that you have i bet the little wire on the starter is on the wrong bolt/tab thingy
dstang97
33
Clover, SC
I think you should get a multi meter or at least a test light and a buddie. See if you are even getting power. The very first thing I would do is DOGHEAD starter relay mod. IIRC the small wire goes on the lug closest to the drivers side on the starter. Search for the bracket its around here somewhere.
