New style light switch issue?
emmado22
165
Mid Hudson Valley NY
Sounds like your switch is dead, just like the many thousands of it's brothers and sisters. I went back to the old style 3 lever switch after burning out 2 of the pushbuttons.. They suck.
BKubu
1,224
Gaithersburg, MD
I have a couple of the switches and have not had any problems with them. However, I have heard that there was a bad "run" of switches. I am not sure the serial numbers, but I was told that these were some of the ones that were cut loose. Perhaps, you have a switch from this lot.
Bruce
Olney, MD
1991 M149A2
1989 M932A2
1989 M925A2
1989 M101A2
1988 M977
1988 M105A2
1987 M1045
1987 M105A2
1985 M1009 (3)
1970 M149A2
1964 M129C
1963 M332 (3)
ida34
35
Dexter, MI
I had the same problem and replaced four relays internally in the switch. It cost me about $30 or so for the parts from digi-key and I had a relative that does electronics replace them. There were four relays and they were surface mount relays. If you take it apart you will see the relays are smoked.
devilman96
17
Boca Raton, FL
emmado hit it... THere is something about the ones produced before (if I remember correctly) 2004 ... ida34 is also correct, changing the relays is not a hard thing ehter.
ojsdna744
Lapeer/Michigan
Re: RE: New style light switch issue?
I love my push button switch. I've made all the 'errors' when operating it and never a hitch. /knock on wood/ I'm just not smart enough to operate the three lever switch! :roll:
sermis
17
Temple, TX
RE: Re: RE: New style light switch issue?
I have one of the take out rebuild. No ground wire. It works ok. What I don't like is that if you do not turn it off it has a light that stays on and drains the battery. On the three lever switch if I left it on it did not run down the battery.
Warren Lovell
SAN DIEGO, CA
Replacing the light switch relays..
Can I send the relay to one of you that has done the job and pay you to do the repair. I paid too much to throw this out.
warren
