- 1,164
- 113
- Athens, Ga.
Cause (if it is cross contamination):I am going to check the dip stick and remove the radiator cap and take a look to see if there is any cross-contamination, but if there is, what could be the cause? Also, you think I can safely drive to look for leaks without doing any damage?
Bad head gasket
Internally leaking oil cooler
Cracked head(s)/block/cylinder liner
Safely drive:
Hard to say. If it were me, I would not risk it. But that's easy for me to say, we have multiple deuces and towbars in our motorpool. You may not be so lucky.
I think you said it's a mile and a half-I'd risk it.
This is quite possible.i really think you have a radiator leak.... the greenish tint to the oil pan ect. tells me that it might be blowing onto the fan, check for leaks there too.
